585,759 active members*
3,910 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > Needing some help with the Workspace issue in BCNC.
    Sep 2016
    26
    I am having a couple of workspace issues. The picture and a video can show you the problems I am having.
    https://youtu.be/aGJoZHJsnC0
    15362
    Re: Needing some help with the Workspace issue in BCNC.
    Quote Originally Posted by usajet View Post
    Check your drawing that the X0Y0 is at that point where you want it to start, then when you create the cam file that will be the start point
    Once you home your machine if you do, you then move your tool to the start point of your X0Y0 and Zero the dro for X and Y axes this is then you work offset G54 then you set you Z axes the same way to the top of your work piece and Zero that as well, your first line of code will have X0Y0 your startpoint
    Mactec54
    Sep 2016
    26
    I will check the drawing again and verify my zero's are in the right spot. Thank you mactec.
  1. Another Master Desay xp 380p issue - Velocity Control
    By airbrush in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-22-2019, 04:27 PM
