I have intermittent air blast mapped to USB I/O relay 3. I can control it on/off with the buttons in the PathPilot GUI.
I can also update my Post file in Fusion to generate the appropriate USB I/O on/off commands to turn it on/off with my job.
However, when I press "reset" or the Estop button, that code doesn't get executed.
I imagine I can write a LinuxCNC process plugin that checks wehther status is idle/reset, and if so, turns off the USB I/O solenoid.
But is there a better way to do this, with less changes to PathPilot? I'd prefer to keep PathPilot code untouched if possible.
