585,914 active members*
3,689 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > SCM Routech Record 125 error CN1001: PLC IN BLOCK
    Jan 2019
    Exclamation SCM Routech Record 125 error CN1001: PLC IN BLOCK
    Hello everyone! I have an error with my SCM Routech Record 125 Cnc router. Whenever I launch my Panelmac program the first thing that pops up is an error. I've never had this error before but it is CN1001: PLC IN BLOCK. I have tried clearing and resetting the machine but still no luck. If anyone has any information about this or something similar I would greatly appreciate the input! thanks!
    Jan 2019
    Re: SCM Routech Record 125 error CN1001: PLC IN BLOCK
    Ive been searching on the internet for hours now and found this
    "Cnc in block means the Kvara is blank and needs to be reloaded. Which can be done by a certified dealer tech or a factory tech. Also the 2032 battery in the kvara needs to be replaced.'
    This is probably my problem but just wanted to put it out here if anyone else has the same problem.
    Oct 2019
    Quote Originally Posted by mhill View Post
    Hi
    did you manage to solve the problem, do I have similar symptoms.
  1. Machining error with offline controller DDCSV2.1
    By rishrsoni in forum Controller Cards
    Last Post: 06-05-2019, 01:20 AM
