585,885 active members*
6,103 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Can you Convert A CNC Router to a CNC Foam Cutter with this Driver?
Results 1 to 7 of 7
    Mar 2004
    500
    I was just wondering if you can convert your set up of a CNC wood router and use it as a CNC foam cutter with the Xylotex Driver? Does it have anything to do with the driver in the first place? Or is it just software?
    Thank you very much for your time.
    I really appreciate it.
    Just software. The driver just turns the motors, nothing more.
    Mar 2004
    500
    Thank you very much.
    430
    A CNC foam cutter is 4 axis. As long as you have a 3 axis card and one separte axis, or 4 separate single axis cards, you are OK.
    co
    Mar 2004
    500
    Would it be possible with just 2 axis? And possibly use two motors per channel on the board? The current would probably be cut in half, but a foam cutter does not need that much torque anyway, I think?
    Thanks. :rainfro:
    430
    not sure about that, and you would only be able to cut constand chord wings if it did work.
    co
    Jun 2005
    6
    does your machine plan on using a hot wire string or shapped wire or routr to cut with? we are trying to get a shaped wire head to cut foam and its been a tough haul.
  1. Large CNC Foam Cutter
    By Clax in forum CNC Wire Foam Cutter Machines
    Last Post: 03-16-2009, 02:23 PM
  2. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
  3. Stepper motor for CNC foam cutter
    By Juancar in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2005, 07:23 AM
  4. CNC Router for 1/4" Depron foam
    By CDignition in forum DIY CNC Router Table Machines
    Last Post: 12-30-2004, 01:36 PM
  5. home made CNC wire cutter and router
    By geesville in forum DIY CNC Router Table Machines
    Last Post: 02-06-2004, 03:24 AM
