585,933 active members*
3,803 visitors online*
    Mar 2013
    18
    Help with 17-4 PH
    Machining 17-4 PH Condition H1150 on a citizen swiss. Having trouble breaking chips. I have tried whizcut inserts and sandvik . Was looking to see what other suggestions are out there. My trouble is with roughing cuts I get long stringy chips that wrap around the part not all the time but enough not to be able to run continuously. Any help would be appreciated.
    Nov 2007
    479
    Re: Help with 17-4 PH
    Is your depth of cut greater than the radius of the insert tip? Did you try pushing your feed rate harder?
    Mar 2013
    18
    Yes I am using a .015 radius .I have tried DOC from .050 to .200. Just cannot get it to be consistent. I can run 6-7 parts with no problems then the next 3 will have chips.
    May 2003
    323
    Use groove tool to rough
    Plunge like normal grooving cycle if possible.
    Sent from my MHA-L29 using Tapatalk
    May 2003
    323
    Also you can use neutral vcmt or dcmt tool holder.
