I 've built a small cnc pen plotter based on GRBL (GRBL-28byj-48-Servo).
Inspired from:
this
It 's a version of GRBL modified for unipolar motors + the use of a servo motor for Z axis (that moves the pen up or down).
It 's working ok, now I want to modify it for a small 5mW laser pointer.
With this I want to make PCBs.
The points of the photosensitive PCB that will be exposed to laser will remain on the PCB (after development + etching, of course) while the non exposed area will be removed.
So, my question is how shall I switch on and off the driver (it 's an LM317 based driver) of the laser pointer.
Shall I have to modify the GRBL-28byj-48-Servo code?
If I replace the servo motor with a relay which will control the driver? And leave everything else as is? Will it work?
Maybe I should use some laser engraver software?
(With it as is by now (that is as a pen plotter) I use Inkscape + MI GRBL extension.)
Any help is welcome.
EDIT: I took a closer look at the diode 's driver and it uses a transistor for switching on and off the diode.
