584,858 active members*
4,742 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > ANOTHER Bridgeport Mill conversion ( Build )
Page 1 of 3 123
Results 1 to 20 of 50
    Dec 2006
    87
    Hi guys,
    Think i have gathered enough information to throw this post out there.. Picked up a 3 axis tilty head Boss ( will be delivered tomorrow... so pics will follow ) after reading and re reading many of the excellent threads here i feel like i have decided on my upgrade path. First, i want to say that there are more than a few talented people here and i am inspired to up my game after seeing some of the things you have built and designed. and i want to thank you all ALREADY for all the info that i have absorbed ( or at least i think i have absorbed )
    im intimidated on keeping the original servos .. ( im not that good at electronics and the power supply kinda freaks me out ) not to mention all the wiring. )
    so here goes
    Bridgeport Boss 3 axis Mill
    Linux CNC
    Mesa Cards 5 axis ( still on the fence on pci or network )
    DMM Servos
    hoping to have power lube / fog buster / tool height / draw bar automated
    Looking forward to having you all along for the ride !
    Joe
    Dec 2006
    87
    Re: ANOTHER Bridgeport Mill conversion ( Build )
    Machine is here !!
    Dec 2006
    87
    would you guys know if these are steppers or servos ? and what voltage / amps / and how they are wired ? maybe i can keep them and just install new drivers there are what looks like hour meters on the motor housings the x has 700 and the y has 800 wonder if thats all the time this machine has seen.. ways are exceptional
    Dec 2006
    87
    here is one of the motors... there are no external tags with model numbers etc on them
    Dec 2013
    5717
    This would be a good place to start https://www.cnczone.com/forums/bridg...ko-keling.html
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2003
    73
    That machine has steppers, it looks like a almost new machine, very clean
    Dec 2006
    87
    Thanks Jim!
    Dec 2006
    87
    Quote Originally Posted by Jonp View Post
    thanks Jon! Yes, I think it just sat. No one knew how it operated.
    15362
    Quote Originally Posted by mongoose View Post
    They are steppers, looks like a well looked after Boss 5
    Mactec54
    Dec 2006
    87
    just pulled off the y axis stepper... reached out to DMM to see what they would recommend
    any reason to try and keep the y axis lock and the travel dial ?
    15362
    750W if you are going with the DMM, is your timing pulleys 1:1 or 2:1
    Mactec54
    Dec 2006
    87
    mactec, pulleys are 1 to 1
    thank you
    joe
    15362
    thank you
    joe
    So your mill is either a Boss5 or older Boss series as Boss6 has 2:1
    Just check I think Dmm may have the right nema size motor flange, you won't need an adapter plate if they have this size mounting flange, they have 2 different motors one is NEMA and the other is ISO/metric
    Mactec54
    Dec 2006
    87
    Looks like they have the high voltage 200 volts model that will fit it is 1.3 kW do i need one with a brake ? or not
    Joe
    15362
    Joe
    No that would be way to big 750w is all you need, no brakes needed
    Mactec54
    Dec 2006
    87
    thanks Mactec.. looks like they only have 1.3kW in that size frame
    15362
    Are yes, so you will have to make the adapter plates for the 750w motors this will require also a motor shaft extension or a pulley that has an offset boss
    Attached Thumbnails Attached Thumbnails Bridgeport to Dmm Motor Mount-2.jpg   Bridgeport  to Dmm With Pulley.jpg   Bridgeport Pulley modification.jpg   Bridgeport Pulley modification-1.jpg
    Mactec54
    Dec 2006
    87
    Mactec, I resigned myself to that... lol I ordered one of the dmm nema 34 servos last nite to get started
    Thank you for the pictures !
    Joe
    Dec 2006
    87
    Mactec, would you make this out of steel or aluminum?
    15362
    Most I have done them in 12L14 I think the Y axes is the only one you have to do this way I would not be sure though, some have brought a new aluminum pulley with a boss on it that can make up for the needed extra length, this is about the same amount of work as modifying the original pulley, the adapter mounting plate 3/8 minimum thickness
    Mactec54
Page 1 of 3 123
  1. RF-31 Round Column Mill CNC Conversion Build Thread
    By tybeede in forum Benchtop Machines
    Last Post: 12-03-2014, 09:47 AM
  2. Bridgeport Boss Mach 3 Conversion Mill
    By sdmuleman in forum For Sale Only
    Last Post: 07-14-2014, 06:03 AM
  3. Replies: 9
    Last Post: 06-02-2013, 05:08 AM
  4. Bridgeport CNC Conversion
    By nikel in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2012, 03:52 AM
  5. Bridgeport Mill conversion to CNC need help
    By bwpigeon in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2009, 04:35 PM
