585,956 active members*
4,118 visitors online*
Results 1 to 10 of 10
    Jan 2011
    7
    Milltronics 3d program
    I am trying to move programs to a milltronics machine. The only way I have to do this is with a floppy so I am limited on size. My question is, does the O program and the P program have to be the same? That is what I have been told but to me it seems like such a waist of space. So right now I am limited since every program I move is actually double its original size.
    Mar 2017
    63
    Re: Milltronics 3d program
    Why do you even need the p program? Where are you transferring from?
    Sent from my SM-N960U using Tapatalk
    Jan 2011
    7
    I am transferring from a computer via floppy disk. The control won't alow me to load from the floppy without an o and p file.
    Milltronics vm24 centurion 6
    Quote Originally Posted by bmoore View Post
    Mar 2017
    63
    Are you using fastcam or cadcam?
    Jan 2011
    7
    Doesn't matter what software I have used. Fusion, Mastercam and written out by hand.
    Mar 2017
    63
    Quote Originally Posted by russellrought View Post
    Do you have full dos names turned on in parameters. You should be able to load a .tap from your cad cam.
    Jan 2011
    7
    Not sure. We don't have a dnc available. Only floppy ????
    Mar 2017
    63
    Go into parameters enter the password, I think it is under control make sure "use full dos names" is set to yes. No dnc necessary.
    Jan 2011
    7
    That did it. Thank you.
    Jul 2010
    548
    Hi Russell, There are several ways to load programs. how you load and run it will depend on the available memory (Parts storage) RAM, . If the control has been updated to a Single Board Computer ( SBC) etc,
    If it is a SBC I have a program I wrote to zip up about a 4.5MB CadCam file Zip it up and be able to UNZIP directly into the control thru the floppy drive or one of my USB floppy emulator drives This works on SBC and controls that are booting from a hard drive.
    From there, a couple of other option become available,
    I can even update your control to use a thumb drive, This is a full 2GB "hot swappable" thumb drive system that works in DOS. I call it my Super SBC control update.
    Give me a call
    sportybob
    952-288-6340
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Replies: 1
    Last Post: 02-11-2015, 02:38 AM
  3. Replies: 4
    Last Post: 03-06-2013, 07:56 PM
  4. Milltronics centurion V program?
    By dj_pigs in forum Milltronics
    Last Post: 03-10-2011, 03:01 PM
  5. milltronics erroe 02 when trying to run program
    By Buzzcnc in forum Milltronics
    Last Post: 07-03-2009, 06:43 PM
