585,722 active members*
4,271 visitors online*
Results 1 to 10 of 10
    Dec 2018
    36
    Homing in wrong direction
    Hi guys my first post so i hope i make sense. My Taig micromill is homing in wrong direction. It is homing toward top right, it should he lower left shouldn’t it? I do not have homing switches or limit switches so i have those disabled. Can some clarify my question thank you. Also FYI i have axis Y and Z reversed in Home/Soft limit menu, i think this has somthing to do with homing in wrong direction. Also i have my table setup as X= 9.00 soft max and Z=0 soft min and Y=6.0 softmax and Y=0 softmin, and Z=0 Sofmax and Z-6.00 softmin in Home/Limit menu. hope it makes sense
    Re: Homing in wrong direction
    If you don't have home switches, it shouldn't be doing anything.
    Home can be anywhere you want it to be, but you probably mean machine zero?
    With a mill, look at it as tool direction, not table direction.
    Dec 2018
    36
    Hi ger21 thanks for reply. Can you give me a brief explanation how it works without home switches? So what i understand i can pickup G54 anywhere?
    If you don't have home switches, Machine zero (G53) is set to the current tool location when you press Ref All.
    You can set your G54 origin any where you want, by just moving there, and zeroing the axis.
    Dec 2018
    36
    Ahh ok thank you again ger21!
    Dec 2018
    36
    Quick question ger21 everytime i execute a gcode program do i have to Ref all home, then pick up my g54? It doesn’t matter where the tool is for g53 correct? As it will establish a x0 and y0 where it is at?
    You don't need to Home the machine at all.
    Dec 2018
    36
    Go just set g54 ( x0 y0 z0) anywhere i want and go from there?
    Yep.
    Jun 2011
    692
    It's probably still a good idea to set soft-limits and reference the machine somewhere (usually the low extremes of X and Y and top of Z.) That way Mach will know to stop if you or your code tells it to move somewhere it can't.
