585,715 active members*
4,056 visitors online*
Results 1 to 9 of 9
    Jan 2019
    4
    SYSTEM DATA SAVE
    I want to know how to save a Memory card
    Power Mate i -MODEL H
    A02B 0259 B501
    FILE DIRECTORY
    1 NC BASIC
    2 PMC1OPT1
    3 PMCAOPT2
    4 PMC0BSC
    5 NC1 OPTN
    6 DG2SERVO
    Thank you.
    Oct 2014
    137
    Re: SYSTEM DATA SAVE
    For load and save the system files you need to actuate the extended menu of Boot Loader.
    Jan 2019
    4
    Quote Originally Posted by agering View Post
    I use the touch screen version, so it has the difference of the command button.
    FANUC A02B-0259-C213 LCD W/ TOUCH PANEL
    Attached Files Attached Files
    Oct 2014
    137
    Your touch panel is connected through HSSB board as panel i?
    Jan 2019
    4
    Red face Re: SYSTEM DATA SAVE
    Can the file system be saved to the memory card? I tried and there was a recording error. The is protected file .
    FILE DIRECTORY
    1 NC BASIC
    2 PMC1OPT1
    3 PMCAOPT2
    4 PMC0BSC
    5 NC1 OPTN
    6 DG2SERVO
    Aug 2013
    11
    Dear Sir,
    do you have Fanuc 21i_TB NC BASIC system data?
    thanks
    Oct 2014
    137
    Quote Originally Posted by harie_2008 View Post
    Dear Sir,
    thanks
    Please, tell me hardware configuration of your system.
    Apr 2021
    Quote Originally Posted by Sokul View Post
    FILE DIRECTORY
    1 NC BASIC
    2 PMC1OPT1
    3 PMCAOPT2
    4 PMC0BSC
    5 NC1 OPTN
    6 DG2SERVO
    Did you manage to backup system data save? I need same thing now.
    Dec 2009
    952
    there are many version of the NC basic so you need to know what version you have from data sheet paper.
    Loading another version of NC BASIC will fail to boot the controller
    Fanuc is giving these files with a service visit to your machine.
    good luck
  1. read out time over system data
    By Flyingmatt in forum HEIDENHAIN -> TNC
    Last Post: 03-02-2020, 12:08 PM
  2. Fanuc 18i-ma system data
    By 3G CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-07-2012, 12:27 AM
  3. SRAM backup VS System data save
    By fomaz in forum Fanuc
    Last Post: 05-02-2012, 09:26 PM
  4. System Commissioning Data
    By CPfef in forum Cincinnati CNC
    Last Post: 05-15-2011, 11:50 PM
