584,837 active members*
5,364 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Fanuc Robocut alpha oc wire edm backlash compansation
Results 1 to 9 of 9
    May 2007
    10
    I have fanuc Robocut alpha OC wire EDM having fanuc Series 16-W control. I need to know
    1. How to enable & disable parameter write.
    2. Which parameters are for Axis backlash adjustment.
    Quote Originally Posted by shabbirabbas View Post
    Press the SET key, it will bring up a menu screen. Use the arrow keys to navigate to to the right hand side of the screen, select “macro”. The press the select button for “soft op” (on the bottom on the screen). Use arrow keys to navigate down to PWE enabled, while hovering over PWE enabled type “1” then press insert. I believe a machine restart is required after.
    For the compensation go to the AI screen type 9990 then press page up. Backlash compensation should be in one of those menus.
    Good luck!
    Re: Fanuc Robocut alpha oc wire edm backlash compansation
    Does anuone knows if exist a PARAMETER MANUAL made for Fanuc for an Alpha 0-C with Fanuc 16-W controller?
    Jan 2017
    5
    Quote Originally Posted by andres-cuesta View Post
    Did you find any manual for this Fanuc controller?
    Mar 2016
    322
    I have an operator manual, but there is nothing about parameters.
    Jan 2017
    5
    Could you share it? I'll start looking for some of the parameters and I'll share it if I find it
    Mar 2016
    322
    Sure. Send me some e-mail address.
    Jan 2017
    5
    What is your email, sorry? Mine is [email protected]
    Mar 2016
    322
    It's sent.
  1. Fanuc Robocut Alpha has 401 error at start
    By jimmytek in forum Fanuc
    Last Post: 12-21-2015, 05:23 PM
  2. EDM Cutting Conditions For FANUC Robocut (alpha)-OC and (alpha)-OiA
    By aaronell in forum EDM Discussion General Topics
    Last Post: 11-02-2015, 07:01 PM
  3. Fanuc robocut alpha-OiE
    By pife82 in forum EDM Discussion General Topics
    Last Post: 08-15-2015, 06:22 PM
