Re: Laser not cutting accurately. PLEASE HELP
Does your software have a step length adjustment function setting? For example, if you go into the vendor settings within in the Ruida's RDWorks software, there is a step length figure and when you click on it, it allows you to input the programmed cut length and then the actual cut length so that it comes up with an adjustment factor. You might look for something similar in your software.
"80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
