Re: Heavy Y axis help with stepper sizing.
Originally Posted by
neorules
Hey all,
The question is will my Nema 34 1600 oz steppers (2 for the X) be able to handle a gantry of approximately 150 lbs or more?
The ball screws are double nut 25mm 5mm pitch.
Suggestions on the overall build and if the NEMA 34 steppers are enough to push the heavy gantry.
Thanks JC
Just to put this in perspective, my 4x8 foot moving table router had a single NEMA 34 1200 oz/in stepper driving a 700 lb table with a 40mm, 40mm lead, ball screw using a 1.5:1 belt reduction. Would run rapids at 600 IPM max, 500 IPM rapids in normal operation.
The Y axis carriage weighed about 300-400 lb, also driven by a 1200 oz/in NEMA 34 stepper, at a 1:1 ratio, driving a 25mm, 25mm lead ball screw.
I had the micro stepping set up to give 0.0001'' resolution (not to be confused with over all system accuracy which was in the range of +/- 0.001 inch)
Running 5mm lead ball screws implies high motor rpms to get any speed out of the system, which your 1600 oz/in motors are not capable of. The torque is way overkill, you could gear the motor a 1:4 step up (20mm movement/motor revolution) and be OK.
I like the double nut ball screws, but I would have used a greater lead.
You might also look at the Porter Cable 75182 router motor
Jim Dawson
Sandy, Oregon, USA
