585,880 active members*
8,209 visitors online*
    Z won’t move/cut in program
    Hi all,
    As my post states, I’m new to CNC and Mach 3. I purchased a KL-6090 CNC router from a place in the Chicago area. A desktop with 32 bit Windows 7 and Mach 3 (licensed) was included. I’m attempting my first cuts with machine and the Z is not moving when I load the g-code and start. All 3 axis move just fine when I use the keyboard. The test piece was produced in Aspire and saved out as both a Mach 3 .txt file and a Wincnc .tap file with both files netting the same result. Any help would be appreciated.
    Thanks,
    Anton
    Apr 2004
    5737
    Re: Z won’t move/cut in program
    That's odd - usually an axis that will jog from the keyboard will respond to g-code commands. What happens when you give it a command like G01Z2.5F10 in the MDI panel (make sure there's room for that move)? Do you have any soft limits set in Z?
    Andrew Werby
    Website
    I think I saw 50 in a soft limits field somewhere, but I don’t even know where to find that info. As for the command, do I enter it just as you typed it above and hit enter? (I’ll move the cutter to the center of the wood and re-zero)
    Just to follow up on the command, when I executed the command the cutter moved up slowly and stopped at +2.500
  1. Z axis won't move under program control
    By Mike4703 in forum Mach Mill
    Last Post: 04-20-2020, 11:19 AM
  2. Help with an unexpected program tool move
    By gibsoni in forum Okuma
    Last Post: 05-17-2018, 09:45 AM
  3. Move G54 form program
    By briker in forum G-Code Programing
    Last Post: 04-20-2010, 04:29 PM
  4. OI-TB move part program load to pendant
    By BAFJB in forum Fanuc
    Last Post: 02-02-2010, 10:35 PM
  5. Need help to program 4th axis move
    By garyatfj in forum Mastercam
    Last Post: 04-02-2009, 02:04 AM
