585,994 active members*
5,006 visitors online*
    Jan 2012
    55
    Center of Mass
    I've trying to get ready for the CSWA test and hit a snag I can't get around. I made an assembly and the center of mass is suppose to be X=40.24 Y=24.33 Z=20.75. I can't seem to get it right no matter what I do, I'm sure someone has asked this before as it is a older sample problem. I attached the files and any insight on what I'm doing wrong and how to do it right will be greatly appreciated.
    Dale
    Attached Files Attached Files
    Apr 2019
    4
    Re: Center of Mass
    Hi Dale,
    Did you have any luck with this problem?
    Cheers,
    Phil
  1. Finding Center of Mass (COM)
    By eficonnection in forum Uncategorised CAD Discussion
    Last Post: 11-08-2012, 04:11 AM
  2. Mass-cnc Job Opportunity
    By mkmk123 in forum Employment Opportunity
    Last Post: 09-18-2007, 11:58 PM
  3. Mass software?
    By bdrmachine in forum Mechanical Calculations/Engineering Design
    Last Post: 01-19-2007, 08:33 PM
  4. Need CNC Machinists in MASS
    By StarCatcher in forum Employment Opportunity
    Last Post: 10-27-2006, 07:14 AM
  5. mass produced
    By skeetboy25 in forum I.C. Engines
    Last Post: 08-12-2003, 01:47 AM
