586,013 active members*
4,221 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > POST ISSUE EDGECAM 2011 fanuc milling post
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Nov 2005
    41
    Re: POST ISSUE EDGECAM 2011 fanuc milling post
    Our cam and or code wizard versions are different - still no % at top of program. The files you modified will not open with our version of code wizard.
    Can you tell me what you changed maybe we do it here.
  2. #22
    Dec 2008
    441
    I will try
    1. Under “Chavalier Mill --> NC Style, G-Codes and Modality --> Set Up Sheet
    Turn ON the "Output Setup Header / Trailer"
    2. Under “Chavalier Mill --> NC Style, G-Codes and Modality --> Code Constructors --> NC Program General --> Set-Up Header
    Delete all the text in the output bar and plase the % symbol
    3. Under "Chavalier Mill --> NC Style, G-Codes and Modality --> Code Constructors --> NC Program General --> Set-Up Trailer
    Delete all the text and leave it empty
    Then save it and compile. Then run out an code and check it
    Good luck!
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
  3. #23
    Dec 2008
    441
    Don't think this is the most correct way to do it, but i think it will work. The % symbol should be in the top in the "Program Start" but the tool list is been posted out before that...
    So that is because i put it in the Header text...
  4. #24
    Nov 2005
    41
    AHH Yes!!! May I heap praise upon you, I am not worthy...
    Output looks just like we want it.
    The reason for all this is our DNC software does not want to see anything above the % character
    we don't like editing programs
    we still want our operators to be able to see the tool descriptions list
  5. #25
    Dec 2008
    441
    Perfect! Thanks!
    I understand that
    - Robert
Page 2 of 2 12
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Fanuc Qi MD Edgecam Post Processor
    By zekry in forum EdgeCam
    Last Post: 04-22-2016, 02:41 AM
  3. Fanuc 6T Edgecam Post Processor
    By Zoni in forum G-Code Programing
    Last Post: 05-03-2010, 06:02 PM
  4. Fanuc 6T Edgecam Post Processor
    By Zoni in forum Fanuc
    Last Post: 05-03-2010, 05:56 PM
