Thanks Arjay
Thanks Arjay
Main machine frame is finished. Time to move on to the Z-axis.
Z-AXIS ASSEMBLY:
Please note that some of the details are from earlier iterations.
The design and concept is the same.
It is easiest to assemble the Z-axis separately. These are the components for the Z-axis:
Attachment 412992
The two linear shafts:
Attachment 412994
You can utilize any parts of the design for your personal use.
Please contact me if you are interested for commercial application.
Place the square nuts into the slots of the spindle mount frames:
Attachment 412996
Nuts installed and mount frames aligned. Middle nut acts only as a spacer:
Attachment 412998
The four spindle frames with the nuts are stacked and ready for loose assembly:
Attachment 413010
The four spindle mount frames are loosely assembled and each of the two SS shafts is attached to the spindle mount with four 1/4 screws.
That's how it looks from the front:
Attachment 413042
And from the back:
Attachment 413044
Please contact me for commercial applications.
The completed Z-axis/slide/extension plate/spindle mount:
Attachment 413046
With the Z-axis assembled, I'm moving on to the spindle.
SPINDLE CONNECTIONS
Electrical wire (IGUS) uses the spindle's original connector.
I found a fitting rubber booth on Amazon that fits over it and protects it bit more:
Attachment 413088
I am using McMaster Carr's 1/4ID-3/8OD PVC hose for cooling.
I found it to be better than the one I got from HD.
More pliable yet somewhat keeping its shape better.
It will fit into the inlet/outlet clamp with some persuasion:
Attachment 413090
Then the flow indicator is installed on one of the tubing:
Attachment 413092
Cut the ends of tubing flush with the clamp:
Attachment 413094
And attach the tubes to the spindle:
Attachment 413096
Orient the flow indicator flat with the front of spindle:
Attachment 413098
Install the electrical connector. Slip on the rubber booth:
Spindle is ready to be installed into the Z-axis assembly.
Position the bottom of the SS body about 1/8" below the bottom of the mount.
Make sure that the inlet/out side of the spindle is inline with the front of the mount:
Attachment 413102
Tighten down the clamp screws, four of them:
On the back of the mount, there are two interior passages for tubing. Push a 1/4-3/8 tubing through that:
Attachment 413106
Bottom view of the mount:
Attachment 413108
Cut the end of tubing square. Heat up tubing and squeeze the tubing into
the threaded cup end of the 1/4" LocLine hose:
Attachment 413110
Push the tubing/LocLine assembly back up the channel:
The bottom of the mount channel has a 1/4" pipe thread on it.
Screw on the LocLine into it:
Attachment 413114
LocLine installed on one channel:
Attachment 413116
Spindle mount has two channels for LocLine installation in the back.
You can use any of them for air or coolant and you can add them at a later time if you wish.
I will be using just one at this time:
Attachment 413118
The Z-axis / spindle assembly is finished and ready to be installed onto the X-carriage.
I don't remember anymore how many times I changed the design, recut the parts and modified the details.
This is a prototype test mule which can and hopefully will be changed to improve many more times.
Any comments, suggestions or critique is very welcome.
Moving on to the X-Carriage.
X-CARRIAGE ASSEMBLY:
All parts for the X-Carriage:
Attachment 413170
Attachment 413172
I will start the assembly with the lower plate:
Pillow block pairs consist of a top and a bottom part.
Align and slide a ball bushing into the bottom part of the pillow block:
Attachment 413174
Then place the bushing and the block through the opening of the lower plate:
Attachment 413176
And slide the top part of the pillow block onto the bushing:
Attachment 413178
One ball bushing and pillow block set placed:
Attachment 413180
Install the other ball bushing and pillow block set.
That's it for the lower plate assembly:
Attachment 413182
Preparation of the upper plate:
Top view of the upper plate with elongated holes for tramming:
Attachment 413208
And the bottom of the upper plate:
Attachment 413210
Install shoulder screw:
Attachment 413212
And the 37MM angular ball bearing:
Install the remaining two pairs of ball bushings and pillow blocks as on the lower plate:
Attachment 413216
Attachment 413218
All installed:
Attachment 413220
Front view:
Attachment 413222
Back view:
It sure looks nice but the side rails are very high and not very wide. I think your going to have flexing and twist when your cutting. Most builders use 3 inch or 4 inch square extrusions or metal for the side rails or Y axis. Look at some of the commercial builds you will see what I mean. Maybe all your going to use is a small hand router for spindle, if so you will be ok.
Just for demonstration, this is where the servo spacer will be installed:
Attachment 413226
And the servo, a lower power Teknic CPM-SDSK-2321P-RQN:
