585,722 active members*
4,099 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas sl30t spindle encoder ring removal
    Sep 2008
    Long time reader, needs help
    I have two Haas SL30 2006 CNC lathes, both need the aluminum encoder ring replaced on the rear of the main spindle. Both have belt driven spindles from below I don't know the correct procedure to replace these rings ($95 ea.), if I can. I'm not planning on removing spindle from machine, but will be replacing the 4V main drive pulley on spindle and a new motor with pulley during repair (don't ask). I'm sure the old ring can be cut, but how do I install new ring without damaging spindle?
    Any help will be appreciated
    Arcnspark
    Sep 2008
    Re: Haas sl30t spindle encoder ring removal
    I have attached a picture of a SL30T spindle with the Aluminum ring still attached for clarification.
    Arcnspark
    Dec 2013
    5717
    If it is just pressed on, then heat the new one to about 250°-300° and slide it into place.
    A cold chisel and a hammer will take the old one off. A couple whacks between a few teeth should expand it enough that it will just fall off, just like removing an engine flywheel ring gear.
    If it's Loc-Tited in place, then some heat may be required to remove.
    I don't know if it's clocked, but you might put a witness mark on the spindle to align a tooth to.
    Jim Dawson
    Sandy, Oregon, USA
  1. Need Yaskawa Magnetic Encoder Ring UTMSI type will pay $$$
    By zombie1363 in forum Servo Motors / Drives
    Last Post: 05-08-2015, 06:41 PM
  2. Need Yaskawa magnetic encoder ring, UTMSI type
    By zombie1363 in forum Mori Seiki Mills
    Last Post: 05-08-2015, 04:40 PM
  3. The "T" in Haas SL30T
    By Chapin34 in forum Community Club House
    Last Post: 06-13-2013, 05:53 PM
  4. Spindle encoder Haas Mini lathe delivery
    By marto74 in forum Haas Mills
    Last Post: 05-25-2012, 02:53 PM
  5. Haas sl30t turret alignment
    By cncfish in forum Haas Lathes
    Last Post: 01-14-2012, 11:30 PM
