585,754 active members*
3,857 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Wanted A/C servo amps & motors
    Apr 2007
    6
    I am currently retrofitting a 2-axis Plasma table with Camsoft and a Galil motion controller which I have purchased. I would also like to replace the Baumuller amps & motors of which were 3.8N-m, and 1.4N-m. Therefore I am interested in locating similar components (A/C servos) either fairly new or refurbished as long as they are in excellent condition. I realize I may have to purchase new although thought I would try this route as well.
    Bap
    24220
    I gather the present motors are DC Brushed? If they are in good condition I would tend to look at matching them up to modern DC drives like A-M-C.
    AC motors and drives come up on ebay all the time, however it is a bit harder matching up AC motors and drives of different makes, unlike DC brushed which is relatively easier.
    If the present motors use dc tach's, they can be disconnected when using modern drives in the torque mode.
    Going this route it will not be necessary to match motors up or change mounting etc.
    Al.
    Albert E.
  1. WANTED: Digital brushless servo drives and motors
    By rpseguin in forum Servo Motors / Drives
    Last Post: 11-03-2006, 03:19 AM
  2. Access to Fanuc motors/amps for BP Boss, help me choose model
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2006, 05:36 PM
  3. dc motors, volts instead of Amps ???
    By max_imum2000 in forum Shopmaster/Shoptask
    Last Post: 01-21-2006, 02:05 AM
  4. General electric servo motors wanted
    By Rich Monfo in forum CNC Machine Related Electronics
    Last Post: 04-07-2004, 09:05 PM
  5. DC servo amps
    By converterk in forum CamSoft Products
    Last Post: 12-22-2003, 06:09 AM
