585,930 active members*
3,115 visitors online*
    Jun 2015
    11
    PID tuning of new servo setup
    Hi Tom/everybody,
    I have recently made the jump and decided to change the stepper motors on the mill to servo's.
    I have a single servo setup with a new kflop/kanalogue combo in a test configuration - my thinking to be to get it going on the bench, then transplant it to the mill with a known good starting point already setup.
    However, the tuning of the servo has proven to be a tricky beast to tame and I was wondering if you could cast your knowledgeable eye upon what I had achieved so far and whether it could be further improved (which I'm sure it could be).
    After much tuning (and reading of the WIKI) I have arrived at a set of values which seem to have the least following error - however, I am still getting a following error of > 1100 counts.
    There also seems to be quite a bit of noise of the rising/falling edge of the output which is caused by D being set to 64, together with some under/over shoot and I'm wondering if this is normal. The D value also causes a little bit of grumble - is this normal?
    I am running the servo with NO filtering at this point as TBH the bode plot output is somewhat confusing - how do I interpret its output and do I need any filtering?
    So - in summary:-
    1. Can I improve on the current set of parameters at this stage?
    2. Can I reduce the following error or is 1100-1200 counts an acceptable figure?
    3. How do I interpret the bode plot and do I need any filtering?
    I'd just like to re-iterate what I've said before - the kmotion system really is top notch - please keep up the great work.
    Regards,
    Toneski
    Attached Thumbnails Attached Thumbnails IMG_20190201_111528.jpg   pic2.jpg   pic3.jpg   pic4.jpg
    May 2006
    4045
    Re: PID tuning of new servo setup
    Hi Toneski,
    You should be able to do much better. Note when adding load on the motor the tuning will change.
    The error is large because only your P Gain is doing most of the work. With only P gain an error is required to create any output:
    Output = error x P
    So to have a DAC output of ~1800 to command the amplifier to move at your top speed
    1800 / 0.6 = 3000 counts of error would be required.
    In order to have small errors and not to rely on large error and P Gain something else must provide the required output.
    Possibilities are Velocity Feedforward (VFF) or Integrator (I Gain).
    Your I Gain is too small to do much within the time of the move.
    Your VFF is helping and reducing the error to about half.
    I'd suggest removing the Acceleration Feed Forward and increasing the VFF to reduce the error. If the error is negative indicating the motor is lagging behind, increase the VFF. If the error goes positive indicating the motor is surging ahead, decrease the VFF.
    The VFF needs to counteract two things:
    #1 - drag introduced by the way KFLOP implements the D Gain of 64. The amount of VFF for this is:
    64 x 90us = 0.00576
    #2 - provide the DAC output of ~1850 counts at a speed of 450000 counts/sec. The amount of VFF for this is:
    1850 / 450000 = 0.00411
    Total expected ~ 0.00987
    3. How do I interpret the bode plot?
    Please read this. I believe your stimulus is too small and too high frequency so there is little movement and the result is all noise.
    With D Gain you should add a low pass filter to remove spikes in the output. See the section here that begins with "When using D Gain...".
    HTH
    TK
    http://dynomotion.com
    Jun 2015
    11
    Hi Tom,
    Apologies for the delay in replying - life has got in the way. I'll be right back onto this problem - hopefully later today.
    Kind regards,
    Toneski.
    May 2006
    4045
    Hi Toneski,
    I understand. No rush from our end.
    TK
  1. what is the best motor tuning setup for nema17 ?
    By dalibouaziz in forum Mach Software (ArtSoft software)
    Last Post: 01-15-2019, 03:48 PM
  2. MPG (WHB04B) setup and tuning on Mach3
    By Megaplow in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2018, 07:31 PM
  3. G320X Setup and Tuning Videos
    By CoAMarcus in forum Gecko Drives
    Last Post: 05-22-2017, 06:23 PM
  4. Replies: 3
    Last Post: 08-08-2016, 08:55 AM
  5. Just throwing this out there (tuning setup)
    By justCNCit in forum Linear and Rotary Motion
    Last Post: 09-29-2008, 02:27 AM
