585,737 active members*
4,782 visitors online*
IndustryArena Forum > Community Club House > Hack a lightscribe into a CNC laser?
    May 2006
    88
    Hey guys,
    I was just taking a look at those new lightscribe DVD/CD burners, the ones that use a small laser to burn an image onto a disk. Could the laser in one of those be added onto a CNC router or similar and used to do lightweight engraving sort of work?
    May 2005
    405
    The laser is too low in power to engrave anything.
    You need about 8 watts to cut paper.
    Paul
    May 2006
    88
    Ahh, I see. Just out of curiosity, what type of laser does it use to engrave the disks? I don't know anything about the process used in lightscribe.
    May 2005
    405
    The disks have a special coating and I think the laser is causing a chemical change to the ink embedded in it. I'm not sure of the power of the laser but I would think it is less than half a watt.
    Paul
  1. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  2. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  3. Is this laser big enough?.. :)
    By hotponyshoes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-28-2007, 08:04 PM
  4. HP Laser Jet II/III - RPM?
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-10-2007, 01:20 PM
  5. Laser in x3?
    By replicapro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2006, 07:20 PM
