Polygonized G2/G3 Arcs
Since I switched to the MK3 (with old CNC-USB software) I noticed that circles and arcs cut with G2 and G3 commands come out visibly as polygons. It is not much and can be sanded away but this is not desired. I don't believe this happened with the old MK2/9 controller, although I am not totally sure.
Is there a way in "settings" to improve the polygon resolution or to just cut a clean circle/arc?
Also, when enabling "path blend", the machine often accelerates and decelerates much slower than specified in settings, before approaching a sharp corner (less than lookahead angle). So I turned "path blend" off and the machine behaves normally but I was wondering if that is intended behavior.
Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
