585,973 active members*
4,248 visitors online*
Results 1 to 2 of 2
    Aug 2011
    999
    Polygonized G2/G3 Arcs
    Since I switched to the MK3 (with old CNC-USB software) I noticed that circles and arcs cut with G2 and G3 commands come out visibly as polygons. It is not much and can be sanded away but this is not desired. I don't believe this happened with the old MK2/9 controller, although I am not totally sure.
    Is there a way in "settings" to improve the polygon resolution or to just cut a clean circle/arc?
    Also, when enabling "path blend", the machine often accelerates and decelerates much slower than specified in settings, before approaching a sharp corner (less than lookahead angle). So I turned "path blend" off and the machine behaves normally but I was wondering if that is intended behavior.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2017
    1311
    Re: Polygonized G2/G3 Arcs
    Make sure helix interpolation is not disabled.
    Send your g-code and settings to our support if you still have problems.
  1. Replies: 5
    Last Post: 12-10-2013, 03:02 PM
  2. G2/G3 Arcs Yet?
    By Treeline in forum MadCAM
    Last Post: 05-22-2013, 06:03 PM
  3. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  4. I and J 3D arcs
    By mmachining in forum BobCad-Cam
    Last Post: 02-14-2008, 08:01 PM
  5. 3d arcs?
    By stevespo in forum BobCad-Cam
    Last Post: 09-01-2007, 02:02 AM
