585,727 active members*
4,148 visitors online*
    Dec 2011
    18
    Question Acoustic isolation of dust collector
    I'm not sure if this is the right section (there are so many!) and before post I did a search, but perhaps I didn't use the right words.
    In a few days I will receive my new machine and I'm equipping my lab with the mandatory accessories. I bought a dust collector (Holzmann Absaugung ABS 850) but for a mistake (my fault) the noise level is louder than expected. It's hard to find anything below 70 dB, so I'm going to keep it and try to reduce its noise. I live in a flat and I cannot use it as is.
    I wonder if a DIY cabin closed on each side with sound proof panels of 50 mm polyurethane would be enough to cut the noise of 10-12 dB.
    I found a lot of such a panels but they say are for musical studios and their primary application is to "clean" the sound. I'm not sure what type of panels I should buy to maximize the acoustic isolation though the cabin.
    Mar 2018
    70
    Re: Acoustic isolation of dust collector
    There are many videos and infos available if you search for "sound proof cnc (or vac/compressor) enclosure".
    https://www.youtube.com/results?sear...+vac+enclosure
    http://<a href="https://www.youtube....d2nhNf9Tp8</a>
    Oct 2007
    6
    That's all fine but what about the heat build up inside? I think you will have some motor failure if you run too long inside this box. Just my thought.
  1. Dust collector
    By popspipes in forum Tormach Personal CNC Mill
    Last Post: 02-09-2021, 05:06 PM
  2. Dust collector setup,dust hood setup,power connecting
    By allencncrouter in forum Videos
    Last Post: 12-17-2018, 02:47 AM
  3. Router / Dust shoe without vacuum or dust collector / Wind Deflector
    By ajean in forum DIY CNC Router Table Machines
    Last Post: 12-12-2015, 07:42 AM
  4. Dust collector
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 06-30-2007, 02:45 PM
  5. Let’s see that’s dust collector
    By automizer in forum DIY CNC Router Table Machines
    Last Post: 03-15-2006, 01:41 PM
