585,708 active members*
3,895 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > homing x axis with two motors and drivers
Results 1 to 12 of 12
    Mar 2011
    357
    If you are using something like a G540 and MACH3 and you have an axis with 2 motors on it you can home each separately to maintain squareness of your gantry.
    How do you do that using GRBL and UGS?
    Mar 2015
    409
    Re: homing x axis with two motors and drivers
    If you want to run 2 motors in sync, connect them to two separate drivers and feed that drivers with the same step/directory/enable signal. Once the motors are setup square, they will remain square.
    Alternatively connect the two spindles by one driving shaft , this is easy to do and works OK.
    If you really need to home the two spindle motors separately then each motor needs a driver that is controlled individually. I don't think it can be done using GRB!
    Mar 2011
    357
    Quote Originally Posted by hfjbuis View Post
    Do you put limit switches on both motors or just one then?
    Mar 2015
    409
    You only need one limit switch because both motors should be in sync (after initial setup).
    Apr 2003
    540
    You should be using the the slave axis settings in Mach. Each motor should have it's own driver. Connecting 2 motors to one axis/driver will work if you reverse the wiring on one, but it's not the best way and can cause other issues.
    Mar 2011
    357
    Quote Originally Posted by coherent View Post
    Except that I am using an arduino and GRBL so there is no fourth axis support. I am driving the 2 motors with 2 drivers from one set of step/direction pins on the arduino.
    What "other issues" can it cause?
    Apr 2003
    540
    Quote Originally Posted by tkms002 View Post
    Instability, loss of torque (each motor would get roughly half the current that the driver would normally supply to one motor), possible timing issues. You are doubling the reactance or inductance applied to the driver. This will likely cause instability and loss of torque of the motors at higher drive frequencies resulting in lost steps. This is a nonlinear function, meaning torque drops more rapidly with increasing drive frequency. This will severely limit the maximum speed of your machine. In addition, the back EMF from two motors under certain operating conditions may add up to the point where it exceeds the voltage rating of the driver which can result in damage to the driver.
    Mar 2011
    357
    Except that I clearly stated that I am driving the two motors with two drivers.
    Mar 2015
    409
    These conditions can happen when you are running 2 motors attached to 1 driver and I agree that is not the way to do it.
    @tkms002 is running 2 motors attached to 2 drivers, so these conditions do not apply to his setup!
    Mar 2011
    357
    Thank you
    Are there any other issues I may encounter?
    1943
    for squaring a stepper driven system with 2 motors on one axis you can simply jog that axis to a set of hard stops, allowing one motor to stall and then the other. It is crude, but works very well. This is how I square the z-axis of my 3d printer. Once square then you can run the homing sequence and both motors will run and stay square.
    Jul 2006
    Quote Originally Posted by 109jb View Post
    Two thumbs up for the best answer. All you need to remember to do is fabricate adjustable hard stops for each end.
  1. Replies: 1
    Last Post: 02-03-2019, 03:10 AM
  2. Tormach PCNC 1100 axis motors and drivers
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 04-18-2017, 01:40 PM
  3. Replies: 0
    Last Post: 12-04-2016, 02:51 AM
  4. Problem - X axis motors fighting each other, can't overcome homing issues.
    By skylineworkshop in forum Mach Software (ArtSoft software)
    Last Post: 10-11-2016, 12:16 PM
