585,996 active members*
4,878 visitors online*
    Jan 2017
    MITSUBISHI MV1200S WIRE EDM TIPS
    Hello guys,
    Can anyone out there help me to run this Mits MV1200s with the door open? I have jobs that the part is way too big to fix in the tank and would like to run it with machine door open. I tried once and the water splashed all over ...lol.
    Thanks guys
    Feb 2019
    5
    Nice post, thank you for sharing. Most people want to achieve their goals but they undermine the importance of confidence. If you want to succeed, you must develop confidence. You should look for reliable websites. So, I recommend downloading facebook video downloader
    Oct 2005
    859
    Post Re: MITSUBISHI MV1200S WIRE EDM TIPS
    I thought I would share this as a help for anyone using these controls. There are so few examples of using this type of programming I decided to test out for a job where we are needing to load and tough off every part from the face and centered on the sides. This is an example of using a program to tough off and set the WKPC before calling a sub program to cut.
    L15/POSITIONG PROGRAM
    (THIS PROGRAM PICKS UP FRONT OF PART AND CENTER OF PART TO SET WKPC)
    (THEN CALLS CUT PROGRAM)
    (ZERO WKPC P10 NEAR FRONT CENTER OF PART IN SETUP)
    (THIS PROGRAM WILL PICKUP PART EACH RUN)
    H10=1 (CUT 1ST FORM 1=YES 0=NO)
    H19=.010 (PART STOCK TO REMOVE FROM FACE---OFFESTS IN Y DIRECTION)
    G62 X0 Y0
    G97 X0
    G70
    G90
    G53 G92 X0 Y0 Z0
    G54.1P10
    G0G90Z0 (MOVE TO Z POSITION JUST FOR SAFETY TO CLEAR IF MOVED)
    G01 X.00000 Y.2000 F40.0000 M91(MOVE TO START)
    M20 M78
    E1401 F0.03000 (CALL EPACK JUST TO SET WIRE TENSION, ETC.)
    M81 M85
    G90
    G92 X.00000 Y.2000 (SET TEMP ZERO)
    (EDGE POSITION FACE)
    G29Y-1P6Q11 (PICKUP FACE IN -Y DIRECTION, Q11 SETS H11 FOR ERROR MESSAGES)
    G14Y12P1 (SET Y AXIS MACHINE POSITION TO H12)
    G43YH12-.0060-H19 (HALF WIRE AND STOCK TO REMOVE)
    H20=H12-.0060 (JUST A CHECK TO SEE VALUE)
    G53 G92 X0 Y0 Z0 (CLEAR AND RECALL WPC---NOT CERTAIN THIS IS NEEDED)
    G54.1P10
    G0G90 X-.25 (POSITION TOWARDS SIDE OF PART)
    Y-.2 (POSITION INTO PART FROM FACE)
    G29X1P6Q11 (PICKUP FACE IN +X DIRECTION)
    G14X13P1 (SET X AXIS MACHINE POSITION TO H13)
    G0G90 X-.25 (MOVE CLEAR OF SIDE)
    Y.2 (MOVE CLEAR OF FACE)
    X.25 (MOVE TO OPPOSITE SIDE)
    Y-.2 (MOVE TO DISTANCE FROM FACE)
    G29X-1P6Q11 (PICKUP OPPOSITE SIDE IN X)
    G14X14P1 (SET OPPOSITE SIDE TO H14)
    H21=H14-H13 (SUBTRACT LARGEST X FROM SMALLER X PICKUP)
    H22=H21/2 (DEVIDE DIFFERENCE BY 2)
    H23=H22+H13 (ADD DIFFERNCE TO SMALLER ABSOLUTE PICKUP)
    (H23=[H14-H13]/2+H13 FULL MATH EQUATION)
    G43XH23 (SET X AXIS CENTER TO MIDDLE OF PICKUPS)
    G53 G92 X0 Y0 Z0
    G54.1P10
    G0G90 X.25 (POSITION CLEAR OF PART NEAR START)
    Y.2
    G01 X.00000 Y.04000 F30.0000
    G201A100B0CH10 (SKIP CUT IF H10=0)
    M21 (CUT WIRE TO MOVE TO SLOT)
    G22L16 (CUT FORM 1)
    N100
    G22L17 (CUT FORM 2)
    M02
    Mar 2009
    22
    thank you your note is much appreciated.
    regards
    AG
    cadcamsa
    Quote Originally Posted by tjones View Post
    G62 X0 Y0
    G97 X0
    G70
    G90
    G53 G92 X0 Y0 Z0
    G54.1P10
    M20 M78
    M81 M85
    G90
    G54.1P10
    G53 G92 X0 Y0 Z0
    G54.1P10
    Y.2
    G22L16 (CUT FORM 1)
    N100
    G22L17 (CUT FORM 2)
    M02
    Oct 2005
    859
    late but thought I would ask a few questions. Do you have auto doors? By ,splashed all over, is that just the spray from the water jets or is is filling the tank? If spray then you need splash guards and if possible cut back on the pressure (LQ) from the e-pack. If it is filling the tank that is simple part of the g-code. Just remove the fill command.
  1. Mitsubishi FX 10 wire EDM
    By LSI Innovations in forum EDM Discussion General Topics
    Last Post: 02-25-2018, 07:44 AM
  2. Cutting speed of MV1200S mitsubishi EDM?
    By Green0 in forum EDM Discussion General Topics
    Last Post: 06-28-2017, 10:57 PM
  3. "WIRE BREAKAGE" alarm on Mitsubishi Wire DWC90HA
    By GEC-ENG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2013, 01:21 PM
  4. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-26-2011, 10:47 AM
  5. Mitsubishi wire type setting for zinc coated wire
    Last Post: 01-25-2011, 01:49 PM
