585,752 active members*
3,895 visitors online*
Page 1 of 2 12
Results 1 to 20 of 39
    Jan 2016
    78
    Drag Chain Cable Management
    I built my 60120 using the supplied 75x25mm & 50x25mm drag chains. I have a total of 12 cables running in my main drag chain (4 x 6mm encoder cables, 4 x 10mm servo power cables, 3 x 6mm proximity sensor cables z, x+, x-, 1 x 15mm VFD flex cable).
    It's pretty crowded in there !
    Looking at the more expensive and industrial drag chain solutions ( I got quoted US$600 for a 150x30mm chain!) you can have 2 layers of cabling, segment the wiring so it doesn't tangle up and cross over.
    Wondering if 3D printing the following inserts, or cutting them out of a foam material is an effective way to avoid problems of cable wear, binding cables etc ?
    Attached Thumbnails Attached Thumbnails Insert.png   75x25mm Chain Insert v9.jpg
    Jan 2016
    78
    Re: Drag Chain Cable Management
    Jan 2016
    78
    One more reason to get a 3D printer. :cheers:
    Jan 2015
    194
    Love it. Had no clue where that thing was going and thought, how does he connect them to make a drag chain but now it is clear. Nice!
    Can you take a picture with the drag chain support popped up and away? And could you post a picture with some general dimensions such as length, width, thickness, and dimensions of the wire channels?
    Thanks for sharing. Really good idea.
    Jan 2016
    78
    I will put the STL files on thingiverse later. Wasn’t sure if people were interested but kept going with the idea.
    I’ve now got inserts for the 50mm wide chain and the 75mm wide chain so you can do the lot.
    I’ve put about 15 of them on the 75mm chain and the spacing seems to work ok.
    Jan 2016
    78
    Jan 2015
    194
    Thanks so much Andrew. Looks great! I've already downloaded and will comment when I've had a chance to print.
    Jan 2016
    78
    Here’s the little ones
    Jun 2017
    369
    Is there room to add any additional cables? I have an led ring on my dust shoe so I can light up my spindle & see what is going on
    Jan 2016
    78
    If you’re using steppers you don’t have encoder and power cables per motor.. should have plenty of space on the 75mm insert
    There’s a spare wire slot on the 50mm insert even for me.
    There’s a detailed info on my thingiverse page
    Jun 2017
    369
    I don't have a 3d printer yet so I'll need to get a quote on someone printing them for me, unless they can be routed
    Jan 2016
    78
    Quote Originally Posted by Gary-Wiant View Post
    I don't think it would be too hard to machine this out of a block of nylon.
    Let me know if you have trouble figuring out dimensions for what you need.
    But on Thingiverse someone can print them for you (for a fee).
    Andrew
    Aug 2017
    34
    Dear God. My cable-management fetish is... well, let's not go there. Just a HUGE thank you!!!!
    Jan 2016
    78
    Glad it’s been useful to you.. also found some 4080 profile cable clips on thingiverse that are brilliant for routing cables
    Jan 2016
    78
    And I also have made a bolt on tray for your touch plate and an Xbox controller holder
    Jun 2017
    369
    I tried to sign in to thingaverse on my phone but when it comes to inputting my birthday, I need to flip from month to month and it would take a long long time to get back to 1967.
    Has anyone created a bracket to mount their 4" flexable dust hose to the side of the Z bracket?
    Jan 2016
    78
    Something like this ?
    ericks Guest
    Wow that is some dust extraction!!!
    Jun 2017
    369
    I was thinking more of a C shaped clamp that mounts to the Z and the hose fits Into but doesn't and much weight to the Z. Also I use the dust shoe from Kent CNC
Page 1 of 2 12
  1. File to make cable drag chain
    By Mike505 in forum MetalWork Discussion
    Last Post: 11-04-2015, 09:25 AM
  2. Plasma cable in drag chain?
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-20-2012, 07:58 PM
