585,978 active members*
4,099 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > UGH - I did something stupid and now I have a mess to deal with
    Apr 2005
    629
    Good morning all,
    I just found out I did something really stupid when I built my CNC router, I believe I used something like an axle grease to lube the ball screws and guideway trucks. I don't have the container anymore (it was about 2 years ago I built the router) so I am not sure exactly what it was, I do recall it was probably red in color.
    Anyway, I happened to reach under the router the other day and my hand rubbed against the ball screw - the grease on it was VERY sticky, almost glue like. I suspect it is drying out. At some point soon, this is going to cause all sorts of problems so I am going to need to clean this crud out. Aside from taking the entire machine apart, does anyone have any suggestions as to how I can clean it up?
    Thanks in advance!
    Chris D
    May 2005
    1662
    Re: UGH - I did something stupid and now I have a mess to deal with
    If you can access whatever retains the wipers I would try sliding the wipers to the ends of the travel. With the wipers out of the way try a combination of movement and some type of friendly solvent.
    Anyone who says "It only goes together one way" has no imagination.
    15362
    Quote Originally Posted by Chris D View Post
    Good morning all,
    Thanks in advance!
    Chris D
    Just remove all the old grease you can get at, and pump in the new correct grease, should be quite easy to clean up with a solvent or a good user friendly degreaser, you should be regreasing your machine every 3 months just a little in the ballnut and the rail bearing is all that is needed
    Mactec54
    Jun 2010
    4256
    Grease tends to hold crud in place. Oil lets the crud flush out. I use oil, not grease.
    Cheers
    Roger
  1. Containing The Mess....
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2010, 02:11 PM
  2. Deal or No Deal? Stepper driver package.
    By voltsandbolts in forum CNC Machine Related Electronics
    Last Post: 05-12-2010, 03:35 AM
  3. Stupid Software making me feel STUPID!
    By StilaR8dr in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2010, 05:12 AM
  4. Am I stupid or is my mill stupid?
    By Ceramic Man in forum G-Code Programing
    Last Post: 08-17-2009, 07:03 PM
  5. 104/d mess
    By mad mark in forum Fadal
    Last Post: 03-22-2006, 09:41 PM
