585,996 active members*
4,725 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Guides for naming part features?
    Oct 2017
    11
    I program/ run various machines and regularly find myself at a loss for words as to what specifically to call a certain part features. Like, is this a "tang" or maybe a "wing", I could call it the "overhang" or the "extrusion". My programs get ran by other people so being able to clearly describe orientation/position of oddly shaped objects is fairly important and I haven't seen any good guides that teach anyone how to properly name features.
    Mar 2008
    683
    Re: Guides for naming part features?
    Just make sure you are consistent and document why a feature is named what it is.
    Dec 2008
    3109
    Each job may be very different to the last one... but as Warrenb says be consistent.
    I try to identify each operation by the feature and what I'm doing to that feature ie ROUGH OUTER PROFILE-XX DEEP...ROUGH TO 1ST STEP... FACE L/H SIDE... SPOTDRILL M8 HOLES.
    if you were doing a complicated shape.... you might put labels on a print for certain features and the use the labels to identify the different operations... but still add info to aid the operators
    ... this aids you as well when debugging little errors ( we all are susceptible to the bugs )
  1. Are Drilling Guides and Tapping Guides the same?
    By SixOfOne in forum DIY CNC Router Table Machines
    Last Post: 05-03-2013, 09:21 AM
  2. Need help naming these chips
    By Luppy in forum MetalWork Discussion
    Last Post: 05-30-2012, 05:27 PM
  3. Replies: 7
    Last Post: 11-02-2011, 10:03 PM
  4. cnc motion control accuracy for small part features
    By knightridar in forum Want To Buy...Need help!
    Last Post: 07-09-2011, 03:14 PM
  5. Request Help naming a part
    By Burnit0017 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2010, 09:05 PM
