I am currently working on setting up a Plasma Table at our shop, and I cannot get the table to execute a full cut. Currently, it will pierce the work piece, and the torch will then shut off (with the gas still running). The problem seems to be in the G-code because I can cycle start, and it will trace out the cut path at a safe Z height. I have notice that the "ArcOK" signal does not activate. I am somewhat of a novice when it comes to Plasma tables so I feel like maybe I am missing something simple. Has anyone else had this problem?
Setup:
- Northern Plasma NV-1 Table
- Hypertherm Powermax105
- SDS Quickcam Pro
- Mach 3
