496,277 active members
6,705 visitors online
Results 1 to 3 of 3
    Registered
    May 2013
    47
    V carve tool path limit?
    Trying to bid a router job so I vectorized the art and tried to create a tool path. If I select a small portion of the vector art a tool path is created BUT if I select it all, no tool path is created. Have I exceeded some limit in BobCAD v27?
    Attachment 411894
    Ghost
    Dec 2008
    4460
    Quote Originally Posted by twoclones View Post
    I doubt it. It's most likely a geometry issue. Vectorizing can be tricky and make a bunch of stuff that needs to be dealt with...
    Ghost
    Dec 2008
    4460
    Re: V carve tool path limit?
    Post the file. Let's see if we can help you get the job!
  1. Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    By eeu23b in forum Uncategorised CAM Discussion
    Last Post: 09-13-2017, 07:12 PM
  2. Replies: 4
    Last Post: 06-14-2016, 02:46 PM
  3. Set height for V-carve path on a model?
    By DonFrambach in forum Vectric
    Last Post: 06-24-2012, 10:47 PM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
