585,719 active members*
4,431 visitors online*
Results 1 to 8 of 8
    Nov 2006
    14
    Exclamation I need help to revive a 810 T GA2 control
    Hello everybody
    I have a lathe with the Sinumerik 810T GA2 control, this lathe was running a few months a go, but now is like dead :drowning:. this is my first Siemens control, I usually work with Fanuc, Fadal, Yaskawa... but never say no to a challenge, well, to resume the CRT is gone, when I turn on the control the power supply keeps resetting, then unplug the monitor and then the power supply remains ON, I don't know if the problem is the CRT itself or the video card, I have some other CRT from other controls, (FANUC, YASKAWA PHILIPS, etc) but i cant find the pin-out of the flat cable.
    Also, I really don't know if the control are alive, they only have a red led blinking on the CPU card, nothing else more, so, any suggestions to check if the control are still working? are de video card gone? the CRT? any suggestions to test the monitor?.
    Just to add, I live in Bolivia South America, so very difficult to get spare parts, only import from USA or Europe. So is expensive and need to be sure before trow money.
    Thanks in advance for the help
    Nov 2006
    14
    Re: I need help to revive a 810 T GA2 control
    Nobody????
    No hay nadie que pueda darme una mano con estos siemens?
    Feb 2011
    353
    i had a 810T that would shut off after power up (about 5 sec) it turned out to be a fan for the control
    this maybe a start for you
    Good luck
    Nov 2006
    14
    Quote Originally Posted by rcs60 View Post
    Good luck
    Thanks for the advice, already check the fans in the beginning of the problem, they are fine,
    Can any body share the pinout for the video flat cable?
    Thanks in advance
    Feb 2010
    12
    If you open the monitor you will see a connector for the flatcable. I think you can see there what the connections are.
    Dec 2013
    39
    Quote Originally Posted by Bordaco View Post
    Hello everybody
    is it CRT or TFT ?
    Nov 2006
    14
    Quote Originally Posted by metalcutting View Post
    is it CRT or TFT ?
    Its a CRT,
    Nov 2006
    14
    yes, I know the +vdc and GND, but very confused on Video, vSync and HSync, I cant get any signal, maybe the video card is toasted, need to try with a video converter, like gombes, but not results.
  1. HELP! revive my dinosaur
    By Hopcycle1 in forum CNC Machining Centres
    Last Post: 10-19-2018, 02:14 PM
  2. Replies: 0
    Last Post: 10-08-2016, 05:36 PM
  3. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  4. revive corrupted file
    By emsee in forum Mastercam
    Last Post: 01-09-2011, 06:34 AM
  5. X2 died. Must revive!
    By voltsandbolts in forum Benchtop Machines
    Last Post: 05-07-2008, 07:30 PM
