585,883 active members*
4,493 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Takisawa lathe with fuji spindle drive issue
    Jan 2010
    321
    Hello
    We have a lathe with a fuji spindle drive. We noticed one day the braking resistors on top of the elect cab glowing red hot while the machine was making parts.
    We shut it down then started it the next day. Ran fine for a few months then glowing red hot again and now spindle drive will not power up at all.
    We turn the ot fanuc cnc on and get not ready on the screen.
    Drive it completely dead.
    Anyone have a clue where to look?
    Drive model is FMD-15AU-21 11/15kw.
    Cheers
    Dec 2013
    39
    Re: Takisawa lathe with fuji spindle drive issue
    Please check the input fuse of drive , than breaking resistor , and control voltage if all are ok , than check the scr module , alarm is of spindle or E stop ?
    Jan 2010
    321
    Quote Originally Posted by metalcutting View Post
    Correct. The alarm 'not ready' is same as having estop pressed.
    I assume the not ready is due to the spindle drive not powering up.
    Will look to check these items and advise the outcome
  1. Takisawa TS-15, Spindle Drive Problem, Fuji DSR Compact, FSD-15DN23, 220V 82A Output
    By mflux_gamblej in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2016, 01:15 AM
  2. Replies: 1
    Last Post: 02-25-2015, 10:00 AM
  3. Fuji Spindle Drive
    By erd39030 in forum Haas Mills
    Last Post: 12-08-2011, 10:01 PM
  4. Spindle drive FUJI FSD-7AH-22.
    By GPena in forum Servo Motors / Drives
    Last Post: 02-09-2009, 07:16 PM
  5. Fuji Spindle Drive.
    By cncdiag in forum Fanuc
    Last Post: 06-20-2006, 03:59 PM
