586,011 active members*
4,046 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Dirise ES100 VFD with 1.5KW Water-cooled Spindle
Results 1 to 7 of 7
    Feb 2019
    4
    Hello,
    I would like to first off thank everyone for providing help with the problem I face.
    A few months ago I purchased a package (VFD and Spindle) as follows:
    Dirise ES100 VFD
    Manual: http://www.dirise.cn/forum/filesyste...xA0NbrCFj67qGw
    Model: DRS ES100-2S-1R5
    220V
    Single Phase
    10A
    Spindle:
    1.5KW Water-cooled
    220V
    400Hz
    5A
    I never received any parameter setup information and am afraid to just guess as I am told to make sure the setup is absolutely correct else I can damage the inverter/spindle.
    If anyone has a similar setup or can please provide some assistance.
    Thanks,
    SNB.
    15362
    Re: Dirise ES100 VFD with 1.5KW Water-cooled Spindle
    Quote Originally Posted by snbinc View Post
    Hello,
    Dirise ES100 VFD
    220V
    Single Phase
    10A
    Spindle:
    1.5KW Water-cooled
    220V
    400Hz
    5A
    Thanks,
    SNB.
    Do or can you get a English VFD Manual, no problem once I have that to give you a Parameter list, I will try and find one
    Mactec54
    Feb 2019
    4
    Sorry didnt realize it was a Chinese manual!
    Here is the english manual: http://www.dirise.cn/forum/filesyste...hyLG4gNmOGK4JM
    Feb 2019
    4
    I also noticed that the VFD is rated for 300Hz while my motor is 400Hz, could this potentially limit the full power of my motor?
    15362
    Then this VFD is not suitable for your spindle it has to match the spindle Hz, see if the seller will change it for you
    Mactec54
    Feb 2019
    4
    Understood, have a bigger problem then :-)
    Thank you for all your help!
    15362
    When you get it sorted I'm here to help you set it up even if it is a different VFD Drive manufacture
    Mactec54
  1. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  2. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  3. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
