Hi!
In my Ikegai TV4 with Fanuc 0M -A the servo control board larmed for high current a couple weeks ago.
Desperate to narrow down what the problem could be I made a misstake one day.
I was shifting X and Y cables on the servoamplifier back and forward but one time i forget to switch the cables from the encoders and the motors strugled and finally larmed and relyas cut off.
I didnt think much at it then and I realized a few days later that there where something wrong with the Y-axis control on the board. A electrician fixed my board and now its back i the machine.
But now I have a diffrent problem, the X-axis is shaking/vibrating when I try to go above 1000mm/min.
I get the worst vibration when I command rapid travers and turn down the feed percentage bellow 50%, the whole machine is shaking.
What do you think? Did my misstake with the encoder cause this problem?
Any idea what i should do to fix my X-axis?
Thankful for help
/Jim
