I bought a second hand 1.8kW 3500 rpm Allen Bradley AC servo and matching drive for about $600 USD (delivered) in New Zealand. Still had to buy cables and
the Rockwell setup software for use as a directly coupled spindle motor, all up about $900USD. Absolutely delighted with how it works.
Quite frankly a lot of that Chinese stuff is that junky that second hand US/European/Japanese stuff is better. AC servos when used as spindles can be indexed very
accurately, programmed in velocity OR torque OR position modes, or maybe a primary mode (velocity) with a secondary mode (position),they are almost too good!.
Have a closer look at secondhand servos and matching drives on EBay. If you are unfamiliar with AC servos I would get a servo and matching drive from the same
manufacturer. You can mix and match servos and drives IF you know what you are doing. I'm glad I have a matching drive...I think I would have struggled
to adapt my servo to another manufacturers drive.
Delta and Teco are good Chinese/Taiwanese brands but I wouldn't trust any of the cheaper Chinese stuff. Beware also that cables and setup software
(depending on the brand) may not be included if buying second hand.
You might like to look at new DMM servos, although I think all the higher power ones are 230V. The company is Canadian and have a good reputation for support
but they manufacture in China so the prices a pretty compelling. Quality at a good price.......
https://store.dmm-tech.com/products/...ac-servo-motor
https://store.dmm-tech.com/products/...nt=20981907526
https://store.dmm-tech.com/collectio...Servo%20Cables
Craig
