585,898 active members*
5,240 visitors online*
Results 1 to 11 of 11
    Jan 2012
    163
    Mill or router
    this year we have a new COO at work* and he stop all government jobs he will not let anybody do any more side jobs.* I'm loosing sleep currently looking for a machine for my home I not sure what to buy a mill and use it for a year and convert to cnc or a cnc router. Was looking at grizzly G0704 or the piranha router A lot money* either way*thinking of going with the mill cause it would be more versatile just thinking. Does anyone have any options on either one would better
    Jun 2018
    362
    Re: Mill or router
    Depends on what you want to make. A mill can make things out of metals and other materials and might have greater accuracy but might be limited to the work envelope and finish quality. A router can also make make many things but might be limited to the materials you can use based on it's size and rigidity.
    You should decide what you want to make and what materials you will use then decide what machine is best. Having both a CNC mill and a router might be even better :-)
    Jan 2012
    163
    Re: Mill or router
    thanks for reply, i would be milling wood for sure, and if needed i was thinking if i ever needed to cut metal i could and it would have a wider range of tools i could use in a mill
    maybe i'm think about this all wrong
    Jun 2018
    362
    Re: Mill or router
    So you need to determine how large your projects will be (largest of course being important). You can't cut big parts on small machines (well not easily anyway). A machine built to cut wood will unlikely cut metals to a reasonable result of repeatable end product. Machine flex, spindle speed, travel speed and accuracy all need to be considered.
    Cheers,
    Jan 2012
    163
    Re: Mill or router
    good point not much bigger then "6x"6 this it why i think a mill would be more versatile cut wood and metal and more tools can be used
    Jun 2018
    362
    Re: Mill or router
    For something that small, yes. A dremel (or better quality) could be used for higher spindle related speeds.
    Mar 2017
    411
    Re: Mill or router
    Instead of the G0704, I would recommend the Precision Mathews PM-25MV. If you are going to convert to CNC later it is better because the saddle requires no modifications and it already has a brushless DC motor. I think the quality is a little better as well. It does cost about $200 more, but I think those things make up for the $.
    Re: Mill or router
    Not sure you could find two more different machines to compare??
    Jan 2012
    163
    I was looking at them to I like them not sure where you came up $200 more I think there listed for$2,299
    And G0704 is 1,450
    Quote Originally Posted by maxspongebob View Post
    Jan 2009
    18
    Re: Mill or router
    Quote Originally Posted by rmachinist View Post
    And G0704 is 1,450
    Grizzly G0704 with stand included is $1495 + $119 shipping. Total is $1614
    Precision Matthews PM25MV is $1699 + stand is $169 + shipping is $169. Total is $2037
    Difference is $423
    The PM25MV is belt drive so it doesn't have any plastic gears like the Grizzly does. The PM also have a variable speed brushless motor. Grizzly has a 1 year warranty and PM has a 3 year warranty.
    Jan 2012
    163
    Re: Mill or router
    you are right
  1. My first router/mill
    By Jakob in forum CNC Wood Router Project Log
    Last Post: 11-03-2018, 01:03 PM
  2. Router vs. mill
    By Ugilten in forum DIY CNC Router Table Machines
    Last Post: 08-10-2016, 12:01 PM
  3. CNC Router/Mill
    By TheHitman04 in forum Open Source CNC Machine Designs
    Last Post: 10-04-2012, 11:52 PM
  4. CNC Mill or CNC Router?
    By spacifique1 in forum Australia, New Zealand Club House
    Last Post: 03-16-2007, 05:59 AM
