Hello All-
I am new to machining and this is my first post. I have yet to run any code on my cnc mini mill. I have learned enough Fusion360 to create some basic objects and I am ready to explore their CAM and run a test file on some balsa foam.
I have run into the following soft limit problem as well as the slow zone not functioning. The Mach3 HTML file is attached:
* Main screen soft limits button will not illuminate, even when I Ref All Home to my limit switches
* Slow zone will not functioning when ref all home, but ref all home is working
* Mach3 HTML file attached
I am new to machining and have yet to run any code on my cnc conversion mini mill. I have learned enough Fusion360 to create some basic objects and I ready to explore their CAM.
Thank you for your time!
Below is my setup:
Mach3?Win7.xxxxx
Probotix PBX-RF breakout board running Probostep drivers
(2 limit switches per axis with ref all home working)
eStop wired to board
LMS mini mill with CNC Fusion conversion
