585,700 active members*
3,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > Toyoda FH63 Fanuc 16i
    Jan 2018
    Hello,
    We have a Toyoda FH63 with a Fanuc 16i. If I turn my B-axis it seems it turns random. Is there a possibility that I can choose if it turns clockwise or counter-clockwise?
    Greetings
    Tom
    Re: Toyoda FH63 Fanuc 16i
    An overrun and a positioning direction are set by the parameter (No.
    5440). Even when a commanded positioning direction coincides with
    that set by the parameter, the tool stops once before the end point.
    G60, which is an one–shot G–code, can be used as a modal G–code in
    group 01 by setting 1 to the parameter (No. 5431 bit 0 MDL).
    This setting can eliminate specifying a G60 command for every block.
    Other specifications are the same as those for an one–shot G60 command.
    When an one–shot G code is sepcified in the single direction positioning
    mode, the one–shot G command is effective like G codes in group 01.
  1. Toyoda FA-550 with Fanuc 15M
    By Lambru in forum Toyoda
    Last Post: 02-14-2018, 04:53 PM
  2. Toyoda . FH 55. Fanuc 15 MA
    By jdeere4250 in forum Fanuc
    Last Post: 12-06-2017, 12:46 PM
  3. FANUC 11m Toyoda
    By dave400 in forum Fanuc
    Last Post: 08-27-2011, 01:34 PM
  4. Fanuc 16i and Toyoda
    By RAC in forum Fanuc
    Last Post: 10-27-2006, 01:28 AM
  5. Fanuc 16i and Toyoda
    By RAC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-19-2006, 01:48 AM
