https://www.ebay.com/itm/183684947985
more infomation please feel free to contact
[email protected]
849047985068 whatsapp
thanks your visit
[email protected]
thanks your visit
Does it have encoder feedback?
i have 3 type spindle
Spindle 3kw 220V pole 4 pole
nominal voltage 220V rated frequency 400hz max 600hz
Max rotation speed 18000rpm
Water cooling
Body diameter 100mm length 450mm weight 16kg
BT30 grip clamp, pneumatic pressure release clamp 6kg / cm2
3 bearing, front 2pcs 7007, back 1pcs 7005, all p4 china bearing
Spindle 5.5kw 4 pole 380V
nominal voltage 380V nominal frequency 400hz max 600hz
Water cooling
Body diameter 125mm length 500mm weight 25kg
4 bearing, front 2pcs 7008, back 2pcs 7006, all p4 china bearing
Spindle 5.5kw 4 pole 220V
nominal voltage 220V nominal frequency 400hz max 600hz
Water cooling
Body diameter 125mm length 460mm weight 25kg
