585,959 active members*
5,142 visitors online*
    Jun 2016
    5
    2 brass pieces milled
    Hi
    Personal project - I need small two sculptural shapes milled out of brass. maybe best done in 5 axis.
    - Needs to be delivered to Brooklyn for the Monday the 25th.
    - they are prototypes and the stock dimensions can change slightly if needed.
    Currently drawn to 3 x 4 x 6 inch pieces of brass stock.
    - The bases would be clamped for milling then ground off. I have drawn these as separate components in the file.
    link below:
    https://a360.co/2SZTNrC
    Thanks for the quotes,
    Tony
    May 2003
    323
    Re: 2 brass pieces milled
    Link doesn't work.
    Sent from my MHA-L29 using Tapatalk
  1. Small brass pieces
    By Erik D_lux in forum RFQ (Request for Quote)
    Last Post: 12-09-2018, 12:56 PM
  2. Smallish aluminum and brass pieces
    By Erik D_lux in forum North America RFQ's
    Last Post: 06-14-2017, 05:27 PM
  3. RFQ - Brass turning two parts 2000 pieces each.
    By R1_pilot in forum North America RFQ's
    Last Post: 07-20-2015, 04:21 PM
  4. RFQ: 100 pieces brass disks.
    By tskguy in forum North America RFQ's
    Last Post: 02-07-2013, 03:41 PM
  5. Brass pieces to be cut or stamped.
    By Ty G in forum North America RFQ's
    Last Post: 10-14-2012, 07:37 PM
