585,752 active members*
4,499 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > A2100 start up diagnostics
    Mar 2018
    9
    Hello
    I had the "Power supply malfunction" fail (8004e) many times without any dependence and tendency, so I was adviced to disassembly, clean the ISA ports and assembly again all the components of the controller. I disassembled, cleaned carefully with fine sandpaper the ISA's for any oxidations (male and female), blew them with compressed air and assembled again.
    1. As result the system started to fail on the hardware diagnostics (Bridge board WS- Failed). Only once from about 10 times it passed the whole diagnostics and the machine worked about 1 hour fine, then appeared Realtime timeout (8004d) and since then it won't pass the Bridge board WS diagnostic. On the extended diagnostics appears sometimes 80C31: Failed; Realtime processor power-up: Failed and sometimes
    80C31: OK; Realtime processor power-up: Failed. Can anybody give me advice where should I look for bad connection or something...
    2. What's the proper position for hooking up the reset cable on the Bridge board (pic 1 or pic 2)??? On the pic 3 is how it's connected to the RT board.
    Oct 2016
    128
    Re: A2100 start up diagnostics
    Quote Originally Posted by Kumanov View Post
    Hello
    If you end up needing the boards I have a dismantled machine that might have the same computer.
    Mar 2018
    9
    Quote Originally Posted by dillonfitz View Post
    You have PM
    Hi, try to replace the thermal paste in the processor and also ad a fan. Mine did that and was only the bad thermal paste that was never changed and should be changed evey 2 years.
    Mar 2018
    9
    Quote Originally Posted by andrecorreia View Post
    Thank you for the advice, I'll try.
  1. Help! Self Diagnostics Systems - What are they?
    By JI7 in forum CNC Machine Related Electronics
    Last Post: 06-05-2010, 06:36 AM
  2. Servo Amp Diagnostics
    By adaptaflex in forum Fanuc
    Last Post: 11-26-2009, 12:01 PM
  3. Help with A2100 extended diagnostics
    By TickTock_ in forum Cincinnati CNC
    Last Post: 10-13-2009, 04:19 PM
  4. Fanuc 10T diagnostics
    By Sprague M in forum DNC Problems and Solutions
    Last Post: 03-25-2005, 08:09 PM
