585,922 active members*
3,784 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Cincinnati Cinturn 000399 spindle open loop error
    Feb 2019
    Exclamation Cincinnati Cinturn 000399 spindle open loop error
    I I have a Cincinnati Cinturn with the Acramatic 850 sx and I am getting a error code open loop on the spindle I’m able to start the spindle and everything sounds good until I get to 275 rpm then the spindle shuts off and the error comes up it always does it at the same rpm being 275 I’m hoping someone has been through this in the manual it says to change the dump board which I have I own two machines toare identical so I switched boards and also switched the resolver cable can anyone help please
    Oct 2020
    12
    Re: Cincinnati Cinturn 000399 spindle open loop error
    I think, yes, there is a lot of information here about your problem. Indeed, I saw several familiar to your question topics and specialists that are ready to do it for you. May be if you provide https://somamedicare.com/
    a little more details here, I will have enough knowledge to do it for you. But what is about the experience?
    Oct 2020
    12
    I have set up and error questions, and I would bet will need parameters. https://calendardream.com/
