585,975 active members*
4,340 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > Code for running 3 stepper motors with raspberry pi
    Feb 2019
    I wan to run 3 stepper motors with raspberry pi and:
    https://www.ebay.com/itm/5x-DRV8825-...53.m2749.l2649
    https://www.ebay.com/itm/SALE-Wantai...53.m2749.l2649
    Its a special CNC-machine so I cant use some CNC-software + I want to learn how to program. I cant find any example how to write the code in python, so i ask anyone here if they know any example?
    As I understand the drivers has auto sequence for the motors so I dont need to program that. If I can get the answer to write the code for 1 full turn for 3 motors at the same time I think I can figure out the rest.
    Thanks!
    Dec 2019
    Hi esod, use this code, and repeat for other 2 motors :
    import RPi.GPIO as GPIO
    import time
    # Variables
    delay = 0.0015
    steps = 30
    GPIO.setmode(GPIO.BCM)
    GPIO.setwarnings(False)
    # Enable pins for IN1-4 to control step sequence
    coil_A_1_pin = 13
    coil_A_2_pin = 5
    coil_B_1_pin = 23
    coil_B_2_pin = 24
    # Set pin states
    GPIO.setup(coil_A_1_pin, GPIO.OUT)
    GPIO.setup(coil_A_2_pin, GPIO.OUT)
    GPIO.setup(coil_B_1_pin, GPIO.OUT)
    GPIO.setup(coil_B_2_pin, GPIO.OUT)
    # Function for step sequence
    def setStep(w1, w2, w3, w4):
    GPIO.output(coil_A_1_pin, w1)
    GPIO.output(coil_A_2_pin, w2)
    GPIO.output(coil_B_1_pin, w3)
    GPIO.output(coil_B_2_pin, w4)
    try:
    while True:
    for i in range(0, 50): $
    setStep(1,0,1,0)
    time.sleep(delay)
    setStep(0,1,1,0)
    time.sleep(delay)
    setStep(0,1,0,1)
    time.sleep(delay)
    setStep(1,0,0,1)
    time.sleep(delay)
    sleep(0.01)
    finally:
    GPIO.cleanup()
  1. Running 2 stepper motors off a single drive
    By laserpilot in forum Stepper Motors / Drives
    Last Post: 12-05-2018, 06:24 AM
  2. Stepper motors not running well
    By tomips in forum Open Source CNC Machine Designs
    Last Post: 02-10-2018, 09:25 PM
  3. Replies: 3
    Last Post: 06-06-2017, 02:02 PM
  4. Running Stepper Motors
    By tmd019 in forum Hobbycnc (Products)
    Last Post: 05-04-2007, 04:10 AM
  5. Unsure About Running Stepper Motors
    Last Post: 04-22-2007, 06:28 PM
