585,933 active members*
3,878 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > How To Set Woodworking CNC Router Controlled By DSP A11
Results 1 to 20 of 20
    Nov 2011
    261
    Lightbulb How To Set Woodworking CNC Router Controlled By DSP A11
    How To Set Parameters In The Rack-driven Woodworking CNC Router Controlled By DSP A11 System,if you have any question?please contact me?
    https://www.youtube.com/watch?v=h1L1...&index=10&t=0s
    https://www.youtube.com/watch?v=pQ1T...&index=11&t=0s
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Feb 2019
    Re: How To Set Woodworking CNC Router Controlled By DSP A11
    Thank you, this is very useful to me. However, I still have some questions. I sent you an email and I look forward to your reply!
    Jun 2018
    362
    Could you please post Q and A here?
    (If it's not private or confidential of course!)
    hello ,if you have any question ,please contact me ,our mail: [email protected]
    To be first brand CNC Manufacturer & Wholesaler platform.
    This is our website?there are a lot of instructional videos on it, if you are interested, please look at it.
    https://www.china-cnczone.com/catego...ol-system/dsp/
    Nov 2011
    261
    Lightbulb Re: How To Set Woodworking CNC Router Controlled By DSP A11
    How To Upgrade DSP A11 Control System
    Nov 2011
    261
    How To Work In DSP A11 Handle Control System
    Nov 2011
    261
    Display The Function Of High/Low Speed Mode In DSP A11 Control System
    Jun 2018
    362
    Do you have a setup guide for setting spindle speed control?
    Nov 2011
    261
    Are you a DSP A11 system, if so, please see:
    Attachment 414014
    On/off button and z+ button are increasing speed
    On/off button and z-button are speed reduction
    Jun 2018
    362
    Thanks for the reply. What you are showing in the picture is how to control spindle speed manually from the hand control.
    This works in two ways:
    1. When the machine is not running G-Code:
    1a. Holding the two-button sequence of "On-Off" and the "Z+" or "Z-" button to increase or decrease spindle speed
    2. When the machine is running G-Code:
    2a. Pressing the "Z+" or "Z-" button to increase or decrease spindle speed dynamically
    What I am asking is how to set up the A11 so that it responds to the spindle speed using the "S rpm_value" word embedded within a G-Code program.
    Apr 2005
    304
    No way.
    A11 has dedicated digital outputs that interfaces with VFD in which are programmed different speeds that correspond to A11 outputs.
    No PWM or 0-10V output from A11 (or any of that kind of CNC controllers with Ti DSP inside, made by Richnc - or knockoffs).
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jun 2018
    362
    Quote Originally Posted by ZASto View Post
    No way.
    Yes, understand the A11 controls spindle speed using a set of binary numbers. (1-8)
    Example spindle speeds:
    6000
    9000
    12000
    16000
    20000
    22000
    24000
    (or similar depending on the spindle/drive combination)
    The above corresponds to the spindle speed steps obtained via the DSP speed numbers 1 through 8. I have my A11 selecting the nearest RPM corresponding to the speed value (1-8) according to the above but am wondering if there is a better way to do it.
    Example, If I select S1 spindle stays stopped. S2000 or S5000 would select 6000 RPM (closest to 6000 and slowest RPM I have), S8000 or S10000 would be 9000 RPM, S16000 is 16000 RPM etc.
    The A11 shows the selected speed using the values 1-8.
    Apr 2005
    304
    Ask Richnc to rewrite the code for dsp
    As I wrote, there is no other way to select spindle speed.
    Nov 2011
    261
    Quote Originally Posted by he1957 View Post
    Hello, friend, you can refer to this video
    https://vk.com/elephantcnc?z=video40...wall_409164950
    How To Use Tool Sensor In DSP A11 Handle Control System
    Nov 2011
    261
    How To Input File In DSP A11 Handle Control System
    Nov 2011
    261
    How To Back To "Home" In DSP A11 Handle Control System
    Nov 2011
    261
    How To Continue To Work After Set The Breakpoint In DSP A11 Handle Control System
    Nov 2011
    261
    Display The Function Of Step Mode And Distance Mode In DSP A11 Contol System
  1. ArduLift - DIY Arduino controlled Router Lift
    By revwarguy in forum Uncategorised WoodWorking Machines
    Last Post: 11-11-2017, 05:44 PM
  2. First job using UCCNC controlled retrofit/refurb Multicam router
    By motogeeking in forum UCCNC Control Software
    Last Post: 08-20-2017, 10:52 PM
  3. Solid state relay controlled router
    By codevark in forum DIY CNC Router Table Machines
    Last Post: 03-26-2009, 12:19 AM
  4. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
