585,971 active members*
4,113 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Estop Triggering; why?
Results 1 to 1 of 1
    Jun 2018
    Angry Estop Triggering; why?
    I've reconstructed a system using Gecko Drive G320X Servo Drivers and have got it to work but I am going crazy with seemingly random Estop interruptions in Mach 3. I have homing and limit switches with shielded cable and am NOT getting errors from them. I was able to run 1000 lines of G-code without interruption twice if I turned off the 1500w VFD and spindle. This suggests the spindle and VFD are responsible for the problem. Conversely when I do an actual cutting job I will get an Estop error at about 400 one time and maybe 800 lines the next time.
    Why is the Estop triggered? Can anyone suggest a technique for tracking down the problem. I have got an oscilloscope.
    Suggestions much appreciated.
