585,996 active members*
4,222 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Mitsubishi Freqrol FR-SF on Single Phase?
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: Mitsubishi Freqrol FR-SF on Single Phase?
    Quote Originally Posted by wmgeorge View Post
    I have built Rotary Phase convertors and they work fine. Your going to need about 50 amps on 240 volts to run a 15 Hp motor on single phase. Lot simpler that trying to run it off a VFD that was never intended to run on single phase input.
    Correction 15 Hp motor here>851150.00 LEESON 15HP MOTOR C256K17FB1A
    Draws 58 amp.... on 230 volts.
    He did not add the VFD it is factory built machine, your 15Hp would not come close to running his machines 30Hp Drive or the rest of the machine in general
    Mactec54
  2. #22
    Sep 2005
    1740
    I do not understand your statement? Here is what he said: t's a 30HP (22kW) VFD, but only a 15HP (11kW) motor, and only 15HP for 30 minutes. 10HP (7.5kW) continuous, and I doubt I'll ever be taking 10HP cuts with it. I said that in the very first post.
    I posted to show the amps draw of a single phase 15 Hp motor, which is 58 on 230 volts ?? He has a 30 Hp VFD drive not a 30 Hp motor.
  3. #23
    15362
    Yes but you have to look at what the manufactures machine electrical Spec requirements are, not what he is posting, they would not use a 30Hp 22Kw VFD if it did not require it, the machine is most likely 100A machine using 3Ph supply
    If he has added the VFD Drive himself then that would be a different story, he is still not going to run it without a RPC of some kind that will have to be CNC rated for the whole machine, if you see the chart below most don't go below 10Hp for single phase use for a reason
    what you just showed was what the motor amp needs are, going through a VFD Drive using single phase you add a minimum of 1/3 more which becomes a lot of amps so you would need a substantial system to be able to even consider running this
    The whole confusion now is the 30Hp 22Kw VFD Drive this will not run unless it see's the right input power
    I just had a look at his video and that's a 100A breaker that is in the machine I think this tells the whole story
    Mactec54
  4. #24
    Sep 2005
    1740
    Well I am with you on this one a RPC would be the answer, not trying to run off a VFD not rated and not feasible for single phase.
Page 2 of 2 12
  1. Mitsubishi FREQROL problem
    By eva_1686 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2020, 04:24 PM
  2. Mitsubishi Freqrol FR-SF
    By mbpp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-28-2010, 10:28 PM
  3. Cable for Mitsubishi inverter Freqrol A 500
    By Tahir Iqbal in forum Community Club House
    Last Post: 07-25-2008, 12:00 PM
  4. Replies: 1
    Last Post: 10-09-2006, 06:19 PM
