585,877 active members*
3,535 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > nm410 / 3016ld forever in 'warmup'
    Dec 2018
    25
    left machine off for 9 days or so, now its forever in the 7 day warm up. It says "KM10 AUX WARMING UP" in the PMC ladder status (at the top of the screen in the PMC ladder). So I looked up all the warming up logic in the ladder (at least I think all of it anways), its looking for M101 to complete, but there isn't any M101 to complete (M101 doesn't do anything)… ideas ? There isn't any mention of M101 I can find in the manual and I've been running the machine since I got it so maybe never got into this state. I also tried just running a few 'warmup' programs for 20-30 mins but this hasn't changed anything.
    Feb 2013
    788
    Re: nm410 / 3016ld forever in 'warmup'
    Our Applications Manager says that the attached might help.
    He thinks that something happened to your Macro programs for Spindle warm-up
    Review the attached.
    If you have questions, call Doosan Machine Tools America, Applications Department General Manager: Robert Appleton at 973-618-2439
    Thanx,
    Attached Files Attached Files
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Dec 2018
    25
    Thanks for the prompt reply. I've operated as per the .PDF but when I do a "S8000; M102;" I just get the machine sitting there waiting with *FIN* displayed... same for M101. THere appears to be nothing happeneing when either is called... I've tried also running the machine at 2000rpm for 30 minuted to try and clear the flag, no dice. What address/macro is M101 natively calling ? I can go about filling it in... ? THanks. Also worth noting: I have M101 in my ladder but not M102.. but M101 I cant seem to get 'set' to on, its address is R6012.1. If I can get that set to "on", seems like the warm up process would complete (according to the ladder). I figure that gets done by the M101 built in macro.. but I all I can find on the machine is my own warm up routine (stored in 9020 so as to be called by M501).
    Feb 2013
    788
    Quote Originally Posted by phatbob View Post
    Program O9020 is called by what ever number is in Parameter 6080. (In the form of an M-code)
    i.e. if 6080 is 101, then the first time the program sees an M101...It is not an actual "M101"...It is a Macro Call using an M-code, same for 6071-6079 for Sub-program calls
    Para# Sub call
    6071 O9001
    6072 O9002
    6073 O9003
    6074 O9004
    6079 O9029
    Para# Macro call
    6080 O9020
    6081 O9021
    6082 O9022
    6083 O9023
    6089 O9029
    So, check that the appropriate number is in the appropriate parameter.
    Dec 2018
    25
    Yes, I've tried that, but M101 in the ladder (R6012.1) never triggers, even though M101 does run my warm up macro as specified by 6080...
  1. LaserPro Mercury II - error - initialising forever.
    By farmersfriend in forum Laser Hardware
    Last Post: 09-01-2016, 09:47 PM
  2. SC9 Saving to Network Drive takes FOREVER
    By jnack95 in forum SprutCAM
    Last Post: 05-20-2016, 09:30 PM
  3. Replies: 2
    Last Post: 07-12-2014, 01:07 AM
  4. Pronest V8 issues with CNC output taking FOREVER to our Torchmate
    By Lockdown in forum Waterjet General Topics
    Last Post: 03-29-2013, 05:18 PM
  5. How I make aerosol Cermark last forever
    By pontiacg5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2012, 03:38 PM
