584,805 active members*
4,854 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > ESS is big improvement over UC100 - however, spindles starts during boot up?
    Apr 2005
    629
    Good morning all,
    I was having all sorts of problems with UC100 having synch errors and disconnects and finally gave up on it. I picked up the ESS Smooth Stepper board from Automation Technologies (it is great having a place where you can go there and pick stuff up within an hour of ordering it!).
    I swapped out the boards and got the machine running. The SmoothStepper lives up to its name - definitely a smooth pulse stream!
    The only issue I have found thus far is that my spindle starts up before the Mach3 software finishes powering up. This never happened with the UC100.
    I know I can leave the spindle off until Mach3 is fully powered, but am looking for a more elegant solution to the problem.
    Is there a way to tweak the settings so this doesn't happen?
    Chris D.
    15362
    Re: ESS is big improvement over UC100 - however, spindles starts during boot up?
    Quote Originally Posted by Chris D View Post
    Good morning all,
    Chris D.
    How do you have the spindle wired to the VFD For and DCM connection
    For the UC100 did you have the correct USB cable this usually is what causes the disconnect problem, it needs to use a double shielded cable to prevent this problem
    Mactec54
    Apr 2005
    629
    The UC100 had been working good for a couple of months, then it started acting up again. I have tried a bunch of different cables etc., but in the end, the problems just come back again - not worth my aggravation to deal with it any longer.
    Regarding the spindle auto-starting problem
    Using the same exact hardware as before (with UC100) ....
    BOB: C10S
    Spindle FWD: Output #2 --> Port 2, pin 17
    Just simple relay control for on/off (FWD/OFF).
    Chris D.
    15362
    BOB: C10S
    Chris D.
    Check the jumpers on the C10S output for the relay you may need to change how it is seeing that signal
    Make sure the Power supply is good for the ESS and it has full power at power up
    Mactec54
    Sep 2005
    1740
    You have a setting wrong in Mach3, your USB cable unless your in a industrial building with lots of EMI present should not be an issue. The spindle being driven by a unshielded VFD and wiring could be an issue IF it was Running but its not. Your on ESS now, correct?
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  3. I put ballscews on my X2, no improvement
    By bmurph in forum Benchtop Machines
    Last Post: 09-08-2012, 04:01 AM
  4. $30 RPM Improvement for LMS3900
    By GG67 in forum Benchtop Machines
    Last Post: 04-02-2012, 02:41 AM
  5. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
