Hello..
I need manual book (operation manual, wiring diagram, hydraulic diagram etc) Amada RG50 with DC-9 II controller.. See photo below
Your help very appreciated.
Thank you.
Hello..
Thank you.
Here is the operator's manual.
Dear Hemikiller,
Thank you for your help..
I have problem the machine after run 4-7 bend the monitor suddenly off. I tried to turn off and on the machine and start run, after 4-7 bend the monitor suddenly off again..
Do you what caroused this problem??
Thank you very much.
Regards.
Sorry, can't help you with the diagnosis. I've never personally run an RG with that controller, ours were Autobackgage 99 and NC9EX II machines, don't know if the one you have ever came to the USA. It does sound like it might be some sort of power supply issue in the controller. You might want to PM Amadajoe here on the CNCZone.
#amadajoe
ba?n co? thê? cho tôi h???ng dâ?n cu?a Autobacgau va? Nc9ex2 không
